Reentrant VI with dynamic input terminal must use 'Share clones between instances' option
This is what LV help says:
A reentrant VI can have dynamic dispatch terminals only if the VI shares clones between instances. This VI preallocates a clone for each instance.
To fix this issue, you must either change the terminal in the connector pane to not be dynamic or change the reentrant execution in the VI Properties dialog box to Share clones between instances.
Do you know why this is so?
Edited by Vladimir Drzik
Dynamic dispatch means that you don't know at compile time which VI will execute, and it would be impossible to preallocate a clone of an unknown VI.
  • Like 2
We talked about the possibility of cloning *all* of the possible subVIs that you might call -- after all, it is a finite set of VIs that might be invoked -- but ultimately we decided that was very rarely useful, to the point that it was better to just steer everyone into the share clones model. If you need some state for your function stored in an uninit shift register, the recommendation is to put that shift register on a static dispatch VI that calls the dynamic dispatch VI as a subVI.
  • 3 years later...
