[Discuss] Truncate Path Xcontrol
index.php?app=downloads&module=display&section=screenshot&id=32
Name: Truncate Path Xcontrol
Submitter: Ton Plomp
Submitted: 03 Jul 2009
File Updated: 21 Sep 2009
Category: X-Controls
Version: 1.1.0
LabVIEW Version: 8.2
License Type: BSD (Most common)
Copyright © 2007, Ton Plomp
All rights reserved.
Author:
Ton Plomp
--see readme file for contact information
Description:
It will truncate a path to fit inside a (multiline) string.
Besides basic funtionality it has the following properties:
  • Truncated string (Read only property that will return the truncated string)
  • Button Visible (Read/Write, this property will show/hide the browse button)
  • Browse properties (Read/Write, this property will set/get the browse options)
  • Multi-Line (Read/Write, this property will set/get the multiline option of the truncated path)
Methods:
  • Truncate Path (this method uses the VIs to truncate a path to a string)
  • Truncate Multiline Path (this method uses the VIs to truncate a path to a multiline string)
For the developer it has the following advantages:
  • Set the browse options with a dialog similar to the native browse options dialog
  • Browse for a path
  • Show/Hide browse button
  • Control the multiline-ness of the control
Known issues:
  • No drag and drop
  • Bounds of indicator/control include (invisible) browse button
Version history
  • 1.1.0
    • Includes multiline truncation
    • Distributed as LLB
    [*]1.0.0
    • Initial release of the code
