gb119 Posted July 25, 2009 Report Posted July 25, 2009 View File Waveform XControl Copyright © 2008, University of Leeds, UK All rights reserved. Author: Gavin Burnell --see readme file for contact information Description: This XControl provides a function generator wrapped up in an XControl that outputs an analogue waveform data type. Supports sine, square, ramp, saw tooth, parabolic, cubic, quartic and arbitrary functions with adjustable amplitudes, offsets, and number of periods with no further coding. User interface provides a graph that updates in response to user changes to the controls. XControl will adjust layout as it is resized, and provides properties to set the visibility of the axes scales, y=0 marker and a current index position marker. Submitter gb119 Submitted 07/04/2009 Category X-Controls LabVIEW Version 2018 License Type BSD (Most common) Quote
gb119 Posted August 27, 2010 Author Report Posted August 27, 2010 Build 10 corrects some packaging errors that caused problems in the previous build. No code changes in this version. Quote
gb119 Posted August 15, 2011 Author Report Posted August 15, 2011 New version that adds the ability to control the format string of the Amplitude/Offset controls - I've set this to default to SI numbers with 3 s.f. Also tweaked the layout code to straighten out the controls somewhat and give a bit more space for the SI prefix. This is likely to be the last LabVIEW 8.6 version as I expect to move to 2011 for future developments soon. Quote
