cs_BOT Posted August 7, 2009 Report Posted August 7, 2009 Hi, Since LabVIEW does not have Database connectivity toolkit for linux. Is it possible to communicate with MySQL database? If yes can some1 explain/illustrate how? regards, BOT Quote
Adam Kemp Posted August 7, 2009 Report Posted August 7, 2009 There may be an open-source LabVIEW mysql API, but if not then you can always write one using the mysql C API (http://dev.mysql.com/doc/refman/6.0/en/c.html). Quote
pallen Posted August 7, 2009 Report Posted August 7, 2009 Hi, Since LabVIEW does not have Database connectivity toolkit for linux. Is it possible to communicate with MySQL database? If yes can some1 explain/illustrate how? There's a tookit here: http://sourceforge.net/projects/sql-lv/ But haven't used it myself. Quote
