Counter output channel
Hi!
I'm having trouble defining a digital output channel as a PWM, using the LabView counter.
I manage to define successfully the task, but when I try to write a new frequency and/or duty cycle, I get an error message saying that the write failed because there are no physical channels associated with the task.
If I check the channel, with a property node, just before trying to write, I do get the correct channel...
Does anyone have an idea what could cause this?
Thanks in advance!
Gavrilo
By the way, the full error message that I get is:
Error -200459occurred at DAQmx Write (Counter Frequency 1Chan 1Samp).vi:2
Possible reason(s):
Measurements: Write failed, because there areno output channels in this task to which data can be written.
Task Name: _unnamedTask<18>
What hardware are you using? It may not be possible to get PWM easily with the E-series cards.
You might just be better of getting a PWM chip and driving that with a Analog output line.
Neville.
