Counter output channel
Hi!
I'm having trouble defining a digital output channel as a PWM, using the LabView counter.
I manage to define successfully the task, but when I try to write a new frequency and/or duty cycle, I get an error message saying that the write failed because there are no physical channels associated with the task.
If I check the channel, with a property node, just before trying to write, I do get the correct channel...
Does anyone have an idea what could cause this?
Thanks in advance!
Gavrilo
