Configuration Headache
I am trying to come up with a Software Configuration Plan for a LabVIEW 7.0 project that I am managing.
My question is this - how can I stop LabVIEW from asking me whether or not I want to save VIs and subVIs that have not been modified? It seems to recompile every VI as it is loaded, and then asks if I wish to save changes when it closes. :roll:
  • 2 weeks later...
A similer question was posted on Info-Labview. Here was my response:
  Quote
> I don't know what version of LV you are using but try this:
> LV7 & 6.1: In Tools>>Options>>Miscellaneous, enable:
> -Treat read-only VIs as locked
> -Do not save automatic changes
> See if this helps.
> Michael Aivaliotis
> > Is there a way to skip the "save" dialog box when shutting down
> > LabVIEW?  I use a mix of common
> > code downloaded from a server and local code specific for each
> > test set.  Whenever I shut down the
> > program (LabVIEW vi's) it will always prompt the tester to "save"
> > all changed vi's.  The changed
> > vi's are from the server and "ask" to be saved because there path
> > has been changed.  But, I don't
> > want the testers to save these vi's.
> > Is there a secret .ini setting or some other method to achieve
> > this effect?
