vugie Posted August 18, 2016 Author Report Share Posted August 18, 2016 For the record - my reply to the same question I received via PM: Waptia works as generic optimization algorithm - you have to provide a function on a number of parameters and algorithm tries to find such set of parameters values for which the function value is the highest. So you'd have to describe any face with a set of variables and write a function in LabVIEW which evaluates how well given set of their values describe face in the given picture. Personally I doubt Waptia is the right direction for such application and even if it is, it's only one of many blocks needed. 1 Quote Link to comment
