freemason Posted September 21, 2009 Report Posted September 21, 2009 Hi all, How do i change the channel to acquire from while running. i have 60 buttons laid out each has channel numbers associated with it in another vi not attached here but for simplicity below is wat i have done the numeric to string will be the channel name+number, since the selectionprocedure happens from a numeric control on FP in my requirement. final goal is i need to be able to select a channel and view its graph on FP without stopping the program. problem is i have 60 channels to read from and thought to make each case foreach channel with corresponding name, but is there a better way to doit. any help is much appreaciated, Thanks in advance select channels programmatically LV8.2_modvi(2).vi Quote
