zythum Posted September 25, 2009 Report Posted September 25, 2009 Hi, I have implement a part of code looking for the version of the executable (with .NET). With this information, I can check if the local exe is up to date versus the exe into network. But, this part of code is very slow if I include this into 2009, ran OK into 8.6. But, if I run those two exe into a computer with LV2009 developpement, the speed are pretty much the same! If I run those into computer with runtime 8.6 and/or 9.0, 8.6 is much faster! Any idea? Thank N.B. png is made form LabView2009 Snippet option example.zip Quote
Shaun Hayward Posted September 25, 2009 Report Posted September 25, 2009 Hi, I have implement a part of code looking for the version of the executable (with .NET). With this information, I can check if the local exe is up to date versus the exe into network. But, this part of code is very slow if I include this into 2009, ran OK into 8.6. But, if I run those two exe into a computer with LV2009 developpement, the speed are pretty much the same! If I run those into computer with runtime 8.6 and/or 9.0, 8.6 is much faster! Any idea? Thank N.B. png is made form LabView2009 Snippet option One thing that might help speed things up would be to use a non-.NET implementation. An example that I have used in the past is to use the FileVersionInfo.vi in vi.lib\Platform\FileVersionInfo.llb - this uses Win32 API calls to get the same information which are normally faster than their .NET counterparts (at least in LabVIEW anyway). Shaun Quote
zythum Posted September 25, 2009 Author Report Posted September 25, 2009 (edited) One thing that might help speed things up would be to use a non-.NET implementation. An example that I have used in the past is to use the FileVersionInfo.vi in vi.lib\Platform\FileVersionInfo.llb - this uses Win32 API calls to get the same information which are normally faster than their .NET counterparts (at least in LabVIEW anyway). Shaun In this case, the Win32 API work fine in LabView 2009 and 8.6. The speed is pretty close. Thank for the "patch". My only concern is for other function, it will be the same problem? Thank Shaun Edited September 25, 2009 by zythum Quote
bmoyer Posted September 25, 2009 Report Posted September 25, 2009 (edited) This library is only available in 8.6+. I guess I could back save it to previous versions. I currently use the .NET method for my programs which are currently in 8.5.1 and I sometimes got complaints that a .NET error occurred (when they didn't have .NET installed). I put in a workaround (hardcoding the version in the code and use that if .NET isn't installed), but this would be better. Thanks for the pointer! Bruce Edited September 25, 2009 by bmoyer Quote
zythum Posted October 30, 2009 Author Report Posted October 30, 2009 This library is only available in 8.6+. I guess I could back save it to previous versions. I currently use the .NET method for my programs which are currently in 8.5.1 and I sometimes got complaints that a .NET error occurred (when they didn't have .NET installed). I put in a workaround (hardcoding the version in the code and use that if .NET isn't installed), but this would be better. Thanks for the pointer! Bruce Do you get it work on LV before 8.6? I find a other way Quote
