aledain Posted January 16, 2004 Report Posted January 16, 2004 I have played a little with the new PDA module. It doesn't allow GOOP objects (I have only tested this on Palm, not PocketPC). Is this because occurrences don't work on the Palm? Anyone have any clues? cheers, Alex. Quote
AndrewC Posted February 16, 2004 Report Posted February 16, 2004 Occurences work with the PDA module. I've never used the GOOP module. Perhaps it uses variants? Those are not supported in the PDA module. Regards, Andrew Quote
aledain Posted February 18, 2004 Author Report Posted February 18, 2004 Maybe it does at the lowest level. It would be nice to program using GOOP, but it does come with an overhead, and maybe that would be prohibitive on the PDA. Quote
Jim Kring Posted March 25, 2004 Report Posted March 25, 2004 Alex, I recommend using OpenGOOP. It will probably work (its pure G + no variants), and if it doesn't work you can fix or strip out the parts that don't. -Jim Quote
aart-jan Posted September 21, 2005 Report Posted September 21, 2005 I know I haven't got the fastest response time, but what I do is in real time The PDA module only has some kind of make believe vi server: it only supports a few properties. That seems to be the most obvious problem to me. It gets even more annoying, because it also behaves inconsistent with clustered data that is any more than simple. Quote
