Novice2006 Posted October 19, 2009 Report Posted October 19, 2009 Hi, I was trying to find a way to calibrate my flexi force using labview but the problem is my limited knowledge in Labview and Interpolation. The attached program takes values via Daq and displays them and also it calculates the rate using the fact that Values above zero are considered as no pressure applied. When I attached the flexi force I ran into problems with calibration. So if you guys could help me out that would be nice. Thank you Quote
PaulG. Posted October 20, 2009 Report Posted October 20, 2009 Hi, I was trying to find a way to calibrate my flexi force using labview but the problem is my limited knowledge in Labview and Interpolation. The attached program takes values via Daq and displays them and also it calculates the rate using the fact that Values above zero are considered as no pressure applied. When I attached the flexi force I ran into problems with calibration. So if you guys could help me out that would be nice. Thank you "Show us your code". Quote
Novice2006 Posted October 20, 2009 Author Report Posted October 20, 2009 "Show us your code". Sorry I Thought I had added it. Latest capstone.vi Linear inter.vi Quote
