Linear Interpolation
Novice2006
I was trying to find a way to calibrate my flexi force using labview but the problem is my limited knowledge in Labview and Interpolation. The attached program takes values via Daq and displays them and also it calculates the rate using the fact that Values above zero are considered as no pressure applied. When I attached the flexi force I ran into problems with calibration. So if you guys could help me out that would be nice.
Thank you
Thank you
