Change size of a wmp (G)Object programmatically
goran
Hi, I have a Windows Media Player activex object on my frontpanel and I want to change the size of that video view programticly while the VI is running. I have checked out the propertie node and I can set the position but not the bounds. The help say's: (of the wmp/GObject)
"You cannot use this propertie to change the size of an object. To change the size of a object programmatically, use a more specific properties such as Text Width or Plot Area:Size."
What property should I use and were can I find it?
Container Bounds:Height and Container Bounds:Width are in the properties list for the ActiveX container.
