Is there an .ini switch that will...?
Is there a hidden .ini switch that will turn off the annoying dialog box that pops up every time I remove a structure? Yes, I know everything in the other cases will be deleted. You don't have to tell me that every time. If I make a mistake... well, that's what cntl-z is for.
I don't know of one and it probably doesn't exist, but I bet you could code up a quick utility or JKI RCF plugin that will do the trick. I've already tested that the Remove Structure method of the Structure class will do exactly what you want.
- Scott
How about adding this to the idea exchange?
I doubt it's flashy enough to attract any attention on the idea exchange. I figured I'd have a better chance of quietly getting an .ini switch put in place.
