How can I convert LVclass object to .NET object?
Dear all,
I meet some problems when I am using OOP in LabVIEW with .NET Container.
In C#, we can show all the properties in Property Grid control.
Now, if I want to show my lvclass object's properties in the Grid, how can I convert LVclass object to .NET object?
I searched the functions inside LabVIEW but coult not find the properly one.
The "To .NET Object" Vi dosen't support LVclass.
Is there anyone who can help me? Thanks very much if you can give an example.
I'm using a .Net container with a windows form 2.0->propertyGrid.
The property being used is "selectedobject". We can get infomation about the PropertyGrid at MSDN.
Thank you again.
You can't. I independently tried this just the other day and the "To .NET Object" method always returns an error method such as the following:
"Error 1199 occurred at Invoke Node in To .NET Object.vi->Untitled 37
Possible reason(s):
LabVIEW: Cannot convert the specified LabVIEW type to .NET object.
Method Name: .NET:Convert To .NET Type"
This is most unfortunate.
Possible reason(s):
Thanks a lot.
I think there must be large differents between lvclass and .net or java class, although they are a bit similar.
I want to use this method as I am interesting in the PropetyGrid in C# 3.5.
In C# class, there is property except member or method which can be used for PropertyGrid~~
Oh, my god, I must write the propertyGrid in LV by myself now.
Maybe you don't need to convert a LabVIEW object to a .NET object. I'm not sure exactly what you need, but if you just want to use the Property Grid control in LabVIEW, that can probably be done. Check out these links
http://zone.ni.com/r...otnet_controls/
http://zone.ni.com/d...da/pub/p/id/230
Mark
Thank you, Mark.
In LV, we could get the property/member one by one, not all at one time.
Otherwise, we can get all properties shown in a Property Grid in C# by giving the "Selected Object" a .net object.
And I think Property Grid is a good partnerf for OOP.
