san_gr Posted November 15, 2009 Report Posted November 15, 2009 (edited) Hi guys, First of all I would like to welcome myself to the forum since that's my first post Now to the problem.... I've been working for a few days on a vi with no problems. Today I tried to open it again and I got a window showing that components are loading and then it freezes when it tries to load a "create empty matrix array" vi. I have to end the process from the task manager and restart labview. I've tried opening other vis and even previous versions of the one causing the problem and they all work fine. I'm attaching a screenshot of the window that opens before the program freezes and also the vi itself. Thank you in advance for any help elevator6.vi Edited November 15, 2009 by san_gr Quote
jgcode Posted November 15, 2009 Report Posted November 15, 2009 (edited) I've been working for a few days on a vi with no problems. Today I tried to open it again and I got a window showing that components are loading and then it freezes when it tries to load a "create empty matrix array" vi. I have to end the process from the task manager and restart labview. I've tried opening other vis and even previous versions of the one causing the problem and they all work fine. Hi san_gr and welcome to the forums! I could open your VI just fine in LabVIEW 2009. The code contains a mathscript node that was empty so I removed it and saved for previous version from LabVIEW2009 to LabVIEW8.2 as you have not stated what version of LabVIEW you where using. Are you able to open the attached? If so it may isolate the issue somewhat. elevator6.vi [LabVIEW8.2] <edit> Under your aviator I see LabVIEW8.6, so I guess this answers one of my questions </edit> Edited November 15, 2009 by jgcode 1 Quote
san_gr Posted November 15, 2009 Author Report Posted November 15, 2009 Are you able to open the attached? If so it may isolate the issue somewhat. Yes! It opens with no problem. Thanks! Quote
jgcode Posted November 15, 2009 Report Posted November 15, 2009 Yes! It opens with no problem. Thanks! No probs [will work for rep points] Quote
