Angle Posted November 22, 2009 Report Posted November 22, 2009 (edited) Hello I develop the vision application for detection the object. In my application, there are two image, one is display real-time, the other is show the defect object. During the run, If I want to double click the defect image, then save this image for analysis later. But when I capture double click to save image, I found the saved image is not that I wanted. The image is the real-time display. The accessory is the printscreen of code . Thanks How to upload many pictures? Thanks grab the image Edited November 22, 2009 by yangui Quote
Angle Posted November 22, 2009 Author Report Posted November 22, 2009 (edited) grab the image find the center of object detection the object and estimate it T OR Flase capture the double-click , save the defect ones First grab the real-time image, Second find the center , 3, detection, If the object is defect, then the image will show in the defect display control. If i want to save the defect object, capture the double-click the defect image, and save it. But i find the save image is the same as the real-time image, not the defect one. And I put a display control in the event structure, it show the real-time image But in event structure, I use the varaible of defect display control. So i am confused Then I think in the application, I am not using IMAQ Creat .VI to open a memory for the defect image , so the defect image save incorrectly. But I creat the memory for the defect image, the result is the same as the previously Edited November 22, 2009 by yangui Quote
