RCF - Snippet Extraction in LV 8.6
jcarmody
I've gotten far enough on my JKI RCF plugin to post it.  Right-click on a snippet, select GetSnippet and it'll replace the decoration with the embedded code. I'd appreciate it if folks would reply with CCT-generated snippets from other versions as I've only tested it with LV 8.6.  I'll work on an 8.2 version this weekend.  Let me know what works and what doesn't and I'll do what I can to make it better.
Special thanks go to Ton and Yair for the CCT, to  Darin.K for showing me how to get snippets from a block diagram and to JKI for the framework.
GetSnippet.llb
It doesn't do well with VIs that contain more than one snippet; it converts the first snippet in the VI and deletes the one you selected. I may fix it by having it convert all snippets rather than only the selected one, but I haven't decided yet.  I'm guessing that we won't often have more than one snippet in a Block Diagram.  Whaddayou think?
