wire connected to undirected tunnel
sydney
I am curious as to why I get an error when I connect the error cluster through the timeout event in either the true or false case. I find it strange that only the timeout event has this problem and none of the other events have this problem! I also can wire around the case statement in the timeout event and get no wiring problem, so there is something that I do not know about the timeout event. An comments are welcome.
I have another question about this code also in the timeout event: I have 4 references to 4 multicolumn listboxes feeding into the init listboxes subVI and one of these has a cast dot. When I made the subVI I included the data type on all four input references and produced strictly typed property nodes to access col hdrs[] and item names. This led to an error for the normalization-listbox reference input to the subVI which goes away when I remove the include data type property in the front panel of the subVI and do not use a strictly typed property node. The code works, but I really do not see what the problem is that requires one reference to be treated with the type cast. Even worse, I have no idea on how I can analytically approach solving this dilemma! I would love to hear any ideas on this problem.
CapProbePrj.zip
Sydney,
Your in luck wrt the event timeout error case.
You accidentally wired the error wire under the structure
<object width="944" height="488"> <param name="movie" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/jingh264player.swf"></param>'>http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/jingh264player.swf"></param> <param name="quality" value="high"></param> <param name="bgcolor" value="#FFFFFF"></param> <param name="flashVars" value="thumb=http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/FirstFrame.jpg&containerwidth=944&containerheight=488&content=http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/2009-12-07_0953.mp4"></param> <param name="allowFullScreen" value="true"></param> <param name="scale" value="showall"></param> <param name="allowScriptAccess" value="always"></param> <param name="base" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/"></param>'>http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/"></param> <embed src="http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/jingh264player.swf" quality="high" bgcolor="#FFFFFF" width="944" height="488" type="application/x-shockwave-flash" allowScriptAccess="always" flashVars="thumb=http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/FirstFrame.jpg&containerwidth=944&containerheight=488&content=http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/2009-12-07_0953.mp4" allowFullScreen="true" base="http://content.screencast.com/users/NJKirchner/folders/Jing/media/1bcbcd14-4133-4cbe-b55c-b926cdc518f8/" scale="showall"></embed> </object>
Also with regards to your second question, right click each of the list-boxes and look at each 'Selection Mode'
That setting declares what kind of data type the MCL is. If it declared to be 0 or 1, then it will be a scalar. If it is one of the 'x or more' then it will be an array.
So really for the code that your doing in the MCL sub-vi (from what I can tell) you don't need to strict any of those references and realize that those kind of coercion dots are ok
good luck
