jon_mcbee Posted January 8, 2010 Report Posted January 8, 2010 Is there a way to get access to the queue that holds events that need to be handled by the event structure? I think that there can be multiple queues if the structure is registered for multiple events, but I assume that at some point they are all loaded onto a single queue for handling. I would like to be able to insert an event at the front of the queue in certain situations to ensure that it is handled immediately. All thoughts appreciated. Regards! Quote
Yair Posted January 9, 2010 Report Posted January 9, 2010 The basic answer is no. If you want to do stuff like that, you need to use a real queue where you can control these things. As for the single queue theory, as far as I know, even that is not true and there are at least two queues (one for user generated events and another for dynamic events), not to mention what happens when you have filter events, which interact with the queue of any event structure which handles them. In any case, since you can't access this information, I see it purely as an implementation detail (or a bug, actually, since under certain conditions it causes unexpected behavior). Quote
Black Pearl Posted January 9, 2010 Report Posted January 9, 2010 You can use an event driven queued state machine (or better described as message handler). You will capture all events in the event structure, but instead of processing them there, you enqueue them as commands. You either can use the enqueue elements at opposite for priority events, or you use multiple queues for several priorities. The processing is handled inside the seperate consumer loop of that queue(s). Felix Quote
jon_mcbee Posted January 9, 2010 Author Report Posted January 9, 2010 You can use an event driven queued state machine (or better described as message handler). You will capture all events in the event structure, but instead of processing them there, you enqueue them as commands. You either can use the enqueue elements at opposite for priority events, or you use multiple queues for several priorities. The processing is handled inside the seperate consumer loop of that queue(s). Felix Thank you both for the response. I plan on using the queued message handler inside my modules, using dynamic events to pass commands from a controlling VI to the modules. I was hoping I could find a way to assign priority levels to these events, so i could broadcast an abort command to all modules registered at a higher priority. I think the solution will have to be that I have a seperate event struct only registered for a high priority event that can take control of the producer/consumer that drives the module. Regards Quote
Black Pearl Posted January 9, 2010 Report Posted January 9, 2010 You also could use a two staged event consumer: * Register the event structure 1 for the abort event and use a timeout (0 or 1 ms), register event structure 2 for the messages and the abort event (use seperate Register for event nodes!) Way1: Place both event structures inside one While loop, force execution flow that event structure 2 only executes after event structure 1 went through timeout OR Way 2: place event structure 2 inside the timeout case of event structure 1 Way one allows to make the event structure 1 a SubVI, I guess it's better to make that one reentrant. But you need a case around structure 2 anyhow (either a boolean from the subVI or throw an error and use that to inhibit execution). What happens (or should happen): * If there is an abort event prior to the loop iteration (fired befor entering the code or during processing an event in structure 2), the structure 1 will catch it, structure two will not be executed and you terminate the loop ELSE * Structure 2 is now waiting to process any events. If this is an abort event, terminate the loop Sounds a bit crazy, but I propably try that pattern myself... Felix Quote
Daklu Posted January 12, 2010 Report Posted January 12, 2010 Thank you both for the response. I plan on using the queued message handler inside my modules, using dynamic events to pass commands from a controlling VI to the modules. I was hoping I could find a way to assign priority levels to these events, so i could broadcast an abort command to all modules registered at a higher priority. I think the solution will have to be that I have a seperate event struct only registered for a high priority event that can take control of the producer/consumer that drives the module. Personally I'm not a fan of using events to issue commands to other modules. Technically you can do it but I don't think it's good design. User events are best used as a way for a module to send information out, not take information in. Use regular VIs to have the module expose commands the controlling vi can issue to it. These VIs simply append the user's data to a pre-defined message and put the message/data package directly on your module's internal message queue. Quote
