ASTDan Posted January 11, 2010 Report Posted January 11, 2010 I have tried to search for this but have found many broken links. How do you set the svn:needs-lock properties for use in a Lock/Unlock model in TortoiseSVN? Thanks Dan Quote
crelf Posted January 11, 2010 Report Posted January 11, 2010 How do you set the svn:needs-lock properties for use in a Lock/Unlock model in TortoiseSVN? You can set it repository wide (I think that only works for new items?), or set it on a file-by-file basis (right click on the file, TortoiseSVN, properties, New..., property name = svn:needs-lock). Our IT dept has a script that runs after TortoiseSVN install that makes our clients add the needs-lock property to all items added to the repo - not sure if I can share that, but let me know if that's what you're asking for. Quote
Mark Smith Posted January 11, 2010 Report Posted January 11, 2010 I have tried to search for this but have found many broken links. How do you set the svn:needs-lock properties for use in a Lock/Unlock model in TortoiseSVN? Thanks Dan Add these properties to C:\Documents and Settings\<username>\Application Data\Subversion\config [miscellany] enable-auto-props = yes [auto-props] *.vi = svn:needs-lock=yes *.ctl = svn:needs-lock=yes *.vit = svn:needs-lock=yes *.ctt = svn:needs-lock=yes *.rtm = svn:needs-lock=yes *.llb = svn:needs-lock=yes *.lvproj = svn:needs-lock=yes *.lvlib = svn:needs-lock=yes *.lvclass = svn:needs-lock=yes Now, all of these file types will get created with the lock enabled - I think - it's been a while since I looked closely at this Mark Quote
