athalia Posted January 12, 2010 Report Posted January 12, 2010 Hi all! I got a problem here.I need to join these two attached VIs. Original state GREEN light on. Press Submit---> RED light l& soilnoid on. Upon Collection Press Submit---> RED light & soilnoid off---->Back to green on. Any help i appreciated! THANKS!!! Password.vi solenoid.vi Quote
nolsqn Posted January 12, 2010 Report Posted January 12, 2010 plz can u explain a bit more wat u want help with .. i am a bit confuse .. Quote
jcarmody Posted January 12, 2010 Report Posted January 12, 2010 Hi all! I got a problem here. First of all, this is cute! Use the boolean Not, instead. I think your problem is that the solenoid VI isn't showing. Right? You can make the form into a dialog and that'll make it work, or you can customize the properties of the window. Use File -> VI Properties (or ctrl-I) and select Window Appearance category. OR You can also simplify the logic in solenoid.vi. I added the Wait function. Quote
