eyal2 Posted January 12, 2010 Report Posted January 12, 2010 how do i drag and drop from Multicolumn listbox to another Multicolumn Listbox?/...any example.. use LABVIEW 8.2.1 and able to rerange the rows in the target multicolumn listbox regard's eyal. Quote
eyal2 Posted January 14, 2010 Author Report Posted January 14, 2010 how do i drag and drop from Multicolumn listbox to another Multicolumn Listbox?/...any example.. use LABVIEW 8.2.1 and able to rerange the rows in the target multicolumn listbox regard's eyal. W O W .......? nobody?..... Quote
Cat Posted January 21, 2010 Report Posted January 21, 2010 Because... the short answer is that you can't do a simple drag and drop from one listbox to another. With most listbox-to-listbox interfaces you select a line in one listbox and then hit a button with code behind it to transfer that line to the other listbox. Same for moving rows up and down. Quote
Francois Normandin Posted January 21, 2010 Report Posted January 21, 2010 W O W .......? nobody?..... Maybe because you didn't even try... <object width="984" height="366"> <param name="movie" value="http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/jingswfplayer.swf"></param>'>http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/jingswfplayer.swf"></param> <param name="quality" value="high"></param> <param name="bgcolor" value="#FFFFFF"></param> <param name="flashVars" value="thumb=http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/FirstFrame.jpg&containerwidth=984&containerheight=366&content=http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/2010-01-21_1200.swf"></param> <param name="allowFullScreen" value="true"></param> <param name="scale" value="showall"></param> <param name="allowScriptAccess" value="always"></param> <param name="base" value="http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/"></param>'>http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/"></param> <embed src="http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/jingswfplayer.swf" quality="high" bgcolor="#FFFFFF" width="984" height="366" type="application/x-shockwave-flash" allowScriptAccess="always" flashVars="thumb=http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/FirstFrame.jpg&containerwidth=984&containerheight=366&content=http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/2010-01-21_1200.swf" allowFullScreen="true" base="http://content.screencast.com/users/normandinf/folders/Jing/media/78b6bdc5-a426-4d64-a0c9-c71cabfa9e6d/" scale="showall"></embed> </object> Quote
Cat Posted January 21, 2010 Report Posted January 21, 2010 I knew if I was wrong someone much brighter than I would respond. They key is to right-click on the control and enable Drag and Drop. Assuming it's there in the version you're using. Quote
Francois Normandin Posted January 21, 2010 Report Posted January 21, 2010 I knew if I was wrong someone much brighter than I would respond. I don't know I qualify for this epitet, but thanks anyway. They key is to right-click on the control and enable Drag and Drop. Assuming it's there in the version you're using. Indeed, I was a little harsh in my statement to eyal2... Eyal... use this code to enable it programmatically (or right-click on your MCL as Cat mentioned) (Works indeed with 8.2) Quote
eyal2 Posted May 11, 2010 Author Report Posted May 11, 2010 I don't know I qualify for this epitet, but thanks anyway. Indeed, I was a little harsh in my statement to eyal2... Eyal... use this code to enable it programmatically (or right-click on your MCL as Cat mentioned) (Works indeed with 8.2) thank's... Quote
