viServer - problem with LV instances
Hi all,
When I tried to run following vi - NI viServer example - in project (not main LV instance), the example didn't work. Everything is fine if I run it in the main LV instance.
C:\Program Files\National Instruments\LabVIEW 8.6\examples\viserver\server.llb\Server - VIServer Example.vi
Is it possible to work (set, run, etc.) in project with viServer? Or viServer has to run in main LV instance only?
LV: 8.6
OS: Windows
Thanks for a help!
What doesn't work?
VI server works perfectly fine in projects, but each project is considered a separate "application", so you have to use the Open Application Reference primitive and use a different port for each project (through the project properties) if you want to communicate between objects.
I didn't look at the example, but I'm assuming this is the source of your problems.
  On 1/14/2010 at 10:42 AM, DaveX said:
I'd love to having viServer working in projects, but :frusty:
Right click on "My Computer" in the project, and enable VI server TCP access (and set another port that 3363 since that is probably in use).
/J
