Kousha Posted January 14, 2010 Report Posted January 14, 2010 Hi there, I want to send data back and forth between a LabVIEW and C# program in real-time. I've read around the site that I can use TCP/IP, but I have no idea what these are, or how can I use them! I am an Electrical/Physics Engineer, so my speciality is not with advance programming Thanks in advance Kousha Quote
Ashwin S Posted January 14, 2010 Report Posted January 14, 2010 Hi there, I want to send data back and forth between a LabVIEW and C# program in real-time. I've read around the site that I can use TCP/IP, but I have no idea what these are, or how can I use them! I am an Electrical/Physics Engineer, so my speciality is not with advance programming Thanks in advance Kousha I don't think TCP/IP is a better option for C# Connectivity, just create a DLL from your C# code and use ' Constructor ' to load that DLL which is found in Fuctions >> Connectivity >> .Net palette in the LabVIEW. Afterwards you can use the Propery and Invoke nodes to call the methods present in the DLL. Ashwin Quote
