MartinMcD Posted March 14, 2010 Report Posted March 14, 2010 Hi there, I'm trying to figure out how to let my sub-panel have access to the parent vi's menu. Hi main vi will be a shell pretty much and then the user will select which DAQ app they want to use on that occasion. That DAQ vi will then be loaded into a sub panel and away we go. However, they sub panel will need to take inputs from the menu, and set it's own applicable menu items. Can anyone help please? I'll keep looking myself and post back if I figure it out. Thanks, Martin Quote
jgcode Posted March 14, 2010 Report Posted March 14, 2010 Hi there, I'm trying to figure out how to let my sub-panel have access to the parent vi's menu. Hi main vi will be a shell pretty much and then the user will select which DAQ app they want to use on that occasion. That DAQ vi will then be loaded into a sub panel and away we go. However, they sub panel will need to take inputs from the menu, and set it's own applicable menu items. Can anyone help please? I'll keep looking myself and post back if I figure it out. Thanks, Martin Hi Martin There is a Current VI's Menubar primitive available in the Functions Palette >> Programming >> Dialog and User Interface >> Menu subpalette. This is a reference to the menu but you will have to pass it down from the Main VI into your subpanel VIs (or use a variable etc...) as it is not exposed through VI Server. Cheers JG Quote
MartinMcD Posted March 14, 2010 Author Report Posted March 14, 2010 Thanks for the reply, that helps. I have found a page on ni.com that shows how to switch menus but the demo is for 2009 and I only have 8.2. I don't suppose anyone could save out an old version for me please? The link is: http://decibel.ni.com/content/docs/DOC-9341 Thanks, Martin Hi Martin There is a Current VI's Menubar primitive available in the Functions Palette >> Programming >> Dialog and User Interface >> Menu subpalette. This is a reference to the menu but you will have to pass it down from the Main VI into your subpanel VIs (or use a variable etc...) as it is not exposed through VI Server. Cheers JG Quote
jgcode Posted March 14, 2010 Report Posted March 14, 2010 Thanks for the reply, that helps. I have found a page on ni.com that shows how to switch menus but the demo is for 2009 and I only have 8.2. I don't suppose anyone could save out an old version for me please? The link is: http://decibel.ni.com/content/docs/DOC-9341 Here you go mate: Select_RTM.zip [LabVIEW 8.2.1] Quote
MartinMcD Posted March 15, 2010 Author Report Posted March 15, 2010 Great, thank you. Here you go mate: Select_RTM.zip [LabVIEW 8.2.1] Quote
