Bar Plots
I have several channels worth of data.
I want to be able to have a horizontal bar plot where each bar represents the RMS value of the channel.
I also need to have some kind of marker to mark the peak value.
Anyone have any experience with bar plots in LabVIEW? I've done a little research and I haven't found a lot. It doesn't seem like it should be this hard.
There's a relevant post here that includes an example with horizontal and vertical bar charts.
  • 1 month later...
i use array or cluster of progress bars for this purpose.
Array: all elements have the same properties
Cluster: Each element can has a unique property
i forgot to mention that you can also add a slider and change the slider fill colour to have a different colour for the section that above the slider value or maximum or limit... as shown
  • Like 2
