george seifert Posted April 5, 2010 Report Share Posted April 5, 2010 (edited) I'd love to be able to put a probe or do some kind of debugging in a callback VI, but it's not working. I have Allow debugging checked and Reentrant execution (Preallocate clone) checked. Do I need to do something different to allow probes? George<br><br>Never mind. If I uncheck Reentrant execution it works.<br> Edited April 5, 2010 by george seifert Quote Link to comment
John Lokanis Posted April 5, 2010 Report Share Posted April 5, 2010 You should be able to do this by saving the callback with a breakpoint on one of the wires or nodes. A callback is simply a dynamically called reentrant VI. When it is invoked, it should stop at the breakpoint and allow you to probe, step, etc... I would suggest enabling retain wires values. Also, I would suggest using shared clones instead of preallocate for all your reentrant VIs. Quote Link to comment
asbo Posted April 6, 2010 Report Share Posted April 6, 2010 You should be able to do this by saving the callback with a breakpoint on one of the wires or nodes. A callback is simply a dynamically called reentrant VI. When it is invoked, it should stop at the breakpoint and allow you to probe, step, etc... I would suggest enabling retain wires values. Also, I would suggest using shared clones instead of preallocate for all your reentrant VIs. I thought I'd throw out there that the key bit here is the breakpoint - otherwise, all you've done is dropped a probe on a VI which is instantiated multiple times in parallel, and LabVIEW doesn't have a way of knowing which instance you want to look at. By placing the breakpoint, a specific instance can be brought to attention, at which point the probe you dropped is tied to that instance. Quote Link to comment
