Making Control !
Could you be a little more specific?
To create a custom control, select it on the front panel of your VI, then from the EDIT dropdown menu, select "Customize Control".
This will open the control editor with your selected control on the panel. From there you can make changes to the control.
As far as advanced control editing is concerned, I won't be able to help you as I don't do much control customizing... yet.
