Mark Smith Posted April 15, 2010 Report Posted April 15, 2010 I've looked thru the LabVIEW faqs and dev zone stuff on 32 vs 64 bit LabVIEW but I can't seem to find an answer to this specific question. That is, if I install LV 32 bit on Win7 64 bit and build an exe (from LV 32 bit), does it build an application that I can install on other 32 bit Win OS's (XP SP2 is the one I have in mind)? I'm in the process of finally upgrading (I get a new machine and I get to install LV2009 finally) and I'm trying to make a decision about whether my primary Win7 OS should be 64 or 32 bit. I have to be able to build code I can deploy to WinXP SP2 32 bit machines. Thanks, Mark Quote
jdunham Posted April 15, 2010 Report Posted April 15, 2010 I've looked thru the LabVIEW faqs and dev zone stuff on 32 vs 64 bit LabVIEW but I can't seem to find an answer to this specific question. That is, if I install LV 32 bit on Win7 64 bit and build an exe (from LV 32 bit), does it build an application that I can install on other 32 bit Win OS's (XP SP2 is the one I have in mind)? I'm in the process of finally upgrading (I get a new machine and I get to install LV2009 finally) and I'm trying to make a decision about whether my primary Win7 OS should be 64 or 32 bit. I have to be able to build code I can deploy to WinXP SP2 32 bit machines. I have this configuration and it works fine. In general a 32-bit app doesn't know anything about a 64-bit OS. It's the OS's job to provide a virtual 32-bit environment for the 32-bit app to run in. So 32-bit LabVIEW is going to build you a 32-bit app which will run fine on XP. Quote
Mark Smith Posted April 15, 2010 Author Report Posted April 15, 2010 I have this configuration and it works fine. In general a 32-bit app doesn't know anything about a 64-bit OS. It's the OS's job to provide a virtual 32-bit environment for the 32-bit app to run in. So 32-bit LabVIEW is going to build you a 32-bit app which will run fine on XP. Thanks for the first-hand info - that gives me confidence that all will be OK! I suspected as much, but I don't have any experience with 64 bit OS's. Mark Quote
