naruto Posted June 1, 2004 Report Posted June 1, 2004 Hi All, I am quite new to LabVIEW, so I still haven't discovered all of the features that experienced users might be able to take advantage of. I was wondering, however, if someone would be able to help me with some front panel related issues. I wish to alter the appearance of an indicator box, on the front panel, by changing it from a recessed box to a flat box, so it can blend in with the background. Is there a way of doing this? Seems simple enough, but I can't seem to find the trick to do this. Any help would be greatly appreciated! Thanks, :beer: Naruto :beer: ps- great forum! :worship: Quote
PJM_labview Posted June 1, 2004 Report Posted June 1, 2004 Naruto, there are several things you can try. 1) Use a classic control 2) Try to change the color of part of the control; you might be able to achieve what you want by just doing that 3) Make the whole control transparent and add a flat decoration frame 4) Edit the control (edit>>customize control) PJM Quote
