pschmal Posted May 21, 2010 Report Posted May 21, 2010 I'm extracting the DFT from a signal I am acquiring from one of the HS Digitizers (USB). The niScope auto-setup does ok, but I could really do with more resolution on my DFT. I've tried to increase the number of min samples, however it seems to just increase the sampling rate so the actual time sampled stays the same. I can't find a way to set the max sampling rate, only the minimum. The current flow is Auto Setup -> Change Property (Min Samples) -> Measure Waveform What magic order do I need to set this? Quote
Ton Plomp Posted May 22, 2010 Report Posted May 22, 2010 I'm extracting the DFT from a signal I am acquiring from one of the HS Digitizers (USB). The niScope auto-setup does ok, but I could really do with more resolution on my DFT. I've tried to increase the number of min samples, however it seems to just increase the sampling rate so the actual time sampled stays the same. I can't find a way to set the max sampling rate, only the minimum. The current flow is Auto Setup -> Change Property (Min Samples) -> Measure Waveform What magic order do I need to set this? What type do you use? and is there some online documentation? Ton Quote
