niScope - increasing real time of sampling
pschmal
I'm extracting the DFT from a signal I am acquiring from one of the HS Digitizers (USB). The niScope auto-setup does ok, but I could really do with more resolution on my DFT.
I've tried to increase the number of min samples, however it seems to just increase the sampling rate so the actual time sampled stays the same. I can't find a way to set the max sampling rate, only the minimum.
The current flow is
Auto Setup -> Change Property (Min Samples) -> Measure Waveform
What magic order do I need to set this?
The current flow is
What type do you use? and is there some online documentation?
