jgcode Posted May 26, 2010 Report Posted May 26, 2010 This came up from this thread at ni.com.... In this example LED XControl by AQ there is a .ico file in the distribution. My question is - is this associated with the Library in any way? Normally when you create an icon for a Library it is a banner-type (e.g. 12x32), not a full 32x32 icon. So all Library members have the same banner. But when want to add the .xctl to the palette it would be nice that you can show an alias icon (as the banner with the bottom bit transparent is not that cool). Is this possible? I could not find anything from searching online or in LabVIEW help. In the LED example it seems the 32x32 icon has been used as the Library icon which means when I "Apply Icons to VIs" (as it is not a banner) it just overrides all icons in the Library which is not preferred. If it is not possible and no-one else has then I would like to post this to the Idea Exchange. Does anyone know? Cheers -JG Quote
jgcode Posted June 17, 2010 Author Report Posted June 17, 2010 [idea posted to the Idea Exchange forum] Quote
