MViControl Posted May 26, 2010 Report Posted May 26, 2010 Hello, I have to use chart in my project since I need draw a real time curve, but I also want to show the grid of the chart (just like graph), but I found there is no option to config this. Can anybody share the information if you done this successfuly before. thx Quote
PaulL Posted May 26, 2010 Report Posted May 26, 2010 Sure there is. Right-click on the chart and select Properties from the pop-up menu. On the scales tab pick the axis and set the options you want under Grid Style and Colors. Quote
MViControl Posted May 27, 2010 Author Report Posted May 27, 2010 Sure there is. Right-click on the chart and select Properties from the pop-up menu. On the scales tab pick the axis and set the options you want under Grid Style and Colors. Thanks, Got it. Quote
