how to Launch and run vi from VB6
The following code will start labview 5.0 with the dialog box, but it doesn't open and run a vi. I need to launch and run the application without a user pushing bottons. Help! :headbang:
Dim LV As LabVIEW.Application
Private Sub Form_Load()
Set LV = New LabVIEW.Application
Debug.Print LV.ApplicationDirectory = "C:\LabViewProgs"
Debug.Print LV.AppName = "MyApp.vi"
End Sub
How about starting labview.exe with the parameter "viname.vi" and make the vi autorun when openend.
You can run executables with the shell methods [shell(Pathname,vbWindowstyle)]. Please note that Labview.exe is not always installed on the same directory, thus track down the latest version and find the appropriate application directory in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\LabVIEW\7.0\Path
Good luck
Hello LabRat,
Did you try the shipping example which shows how to do this? It can be found under examples\comm\VBtoLV.vbp. I am not sure if this example shipped with LabVIEW 5.0 however.
In any case, you should not be using LV.AppName. This is a read-only property that outputs "LabVIEW.exe" (or whatever the built executable's name is). Instead, you should use the Call method on the VI class (passing it the parameter names and values). For details, see LabVIEW Help for 'VI class (ActiveX)'.
Hope this helps. Again, check out the shipping example. I just tried and it works fine. If you do not have the example, you can take a look at the following one from NI's DevZone (I haven't tried this one though):
http://sine.ni.com/apps/we/niepd_web_displ...source=External
Regards,
Khalid
