Problem in serial communication
hi everyone...:worshippy:
i am pravin newbie in this forum....... here is my first post ...
i am using labview 8.6 currently i am doing a project in touch panel pc.. serial comm between micro controller & labview ... problem is i am getting frame error when i try to acess the controls in touch panel... or after some time comm stops & shows a error.. recieve frame visa error...i am using 115200 baurade & one stop bit... i hav checked the hardware is good i don knw hw to solve the problem...:unsure:
plz kindly help me guys...
thanks in advance....:rolleyes:
Are you sure your COM port settings match the device's? Frame error usually indicates you're using the wrong baud rate, at the very least.
thanks for ur reply sir...  :) ya i hav checked intially its running good after some times its getting   error  the code is 1073807253   occurred when visa receive....
Edited by pravinspidy
hi,
sir  i hav solved the problem actually problem is with my serial port hardware...... i have 2 com ports in pc which is connected in parallel port .... wat i did is i had changed the hardware & tested now its working fine...... :thumbup1::thumbup1::beer_mug:
