[Discuss] IE 2009 Update
index.php?app=downloads&module=display&section=screenshot&id=138
Name: IE 2009 Update
Submitter: jgcode
Submitted: 12 Jun 2010
File Updated: 03 Jan 2011
Category: *Uncertified*
LabVIEW Version: 2009
License Type: BSD (Most common)
IE 2009 Update v1.0
Copyright © 2010, Jonathon Green; JGCODE
All rights reserved.
Author: Jonathon Green
LAVA Name: jgcode
Contact Info: Contact via PM on lavag.org
LabVIEW Versions:
LabVIEW 2009 only
Dependencies:
None
Description:
WARNING: This patch is cannot be unistalled.
This package is a repack that contains code posted on NI Forums by NI that applies a fix to the Icon Editor 2009. This was a large patch that fixed a number of CARs. However, this update was not included in the LabVIEW 2009 SP1 release.
This package will install files to the labVIEW 2009\resource\plugins\NIIconEditor folder
In particular, the following CARs are addressed in this service pack:
See here to view the original document and code posted in the Enhanced Icon Editor Group.
151661
This change fixes the copy/cut ability of the icon. If a region is selected and/or a layer is selcted, copy and cut is enabled.
161032
No limit on arrow keys moving text
175010
When moving a selction and changing a layer, the operation is performed on the new layer
179582
Glyph layer moves after deleting a selection (first edit to the layer)
179799
If the bottom layer got deleted, the user layers list is not updated properly
179392
Icon editor open on secondary screen when working with two screens
179000
Switching the tab doesn't actually unselect the layer
179001
CTRL - A followed by pressing the delete key doesn't delete all selected layers
179007
The key binding is messed up. The mirror tool has set as the toggle key, whereas the OK button should have to set the focus.
179179
Control activates dropper and not move tool when pasting an image
180161
It is possible that multiple icon layers are copied in reverse order and neither template nor text layer are considered at all
182276
Icon glyphs do not handle standard transparency
182828
Manual User Input.vi - OK button doesn't stop the while loop
182893
Paste/Cut of text doesn't update the icon text
182992
Populate Tree.vi can not handle folder with a dot in its name
186982
[iE] Wrong Icon is loaded in Icon Editor
Installation and instructions:
Install package using VIPM.
Restart LabVIEW
Examples:
No examples.
Known Issues:
No known issues.
Acknowledgements:
Thomas Sandrisser
Version History (Changelist):
1.0-1 2010 06 12
- New (): Initial public release of the code (LabVIEW 2009)
License:
Copyright © 2010, National Instruments
Support:
If you have any problems with this code or want to suggest features:
please go to lavag.org and Navigate to LAVA > Resources > Code Repository (Certified) and search for the IE 2009 Update support page.
Distribution:
This code was downloaded from the LAVA Code Repository found at lavag.org
