KoBe Posted June 24, 2010 Report Posted June 24, 2010 (edited) Hi people, I would like to know, if it is possible to read all attributes of a Labview class by getting an Array of Variants? I would like to have such a Read Method because I will use all attributes of my class as the description of a TDMS-File. The attributes Type Descriptor Name will be the Property Name in my TDMS and the Value will be the TDMS Property Value. Instead of calling all Read Methods for each single attribute in my class I would like to have a Generic VI with such properties: -Input is a Variant, so I can wire any Class to that input. -Output is a Array of Variants containing all attributes of the input class. This Generic VI will then be a SubVI of the "Read_All" Method of each class to be able to access private attributes. Has anyone an idea how to "typecast" or "Variant To Data" my Input Variant to a Generic Labview Class Reference, where I can access the attributes and their values to put them in my Array of Variants? Bye Corrected Version of my VI, I'm sorry for that. Edited June 24, 2010 by KoBe Quote
K-node Posted June 24, 2010 Report Posted June 24, 2010 (edited) On 6/24/2010 at 8:16 AM, KoBe said: I would like to know, if it is possible to read all attributes of a Labview class by getting an Array of Variants? I would like to have such a Read Method because I will use all attributes of my class as the description of a TDMS-File. The attributes Type Descriptor Name will be the Property Name in my TDMS and the Value will be the TDMS Property Value. Interesting challenge. I do not have a solution. From a different perspective, can you even do what you want with a arbitrary cluster? That is, go from a cluster directly to an array of variants. For a lame solution, the Read_All method has access to all of the class's private data. So you could just use the Unbundle method on the class's data, wire each element to the 'To Variant' method and build the array. Tedious, but perhaps better that calling all of the Read functions. Kurt Edited June 24, 2010 by kugr Quote
KoBe Posted June 25, 2010 Author Report Posted June 25, 2010 On 6/24/2010 at 6:59 PM, kugr said: From a different perspective, can you even do what you want with a arbitrary cluster? That is, go from a cluster directly to an array of variants. Kurt That work, I've a VI which takes a Cluster (input is Variant) and searches for it's contained datatype in the flattened data. Ouput is then an array of clusters. If I would be able to typecast / convert or extract the data cluster (attributes) of my class into a variant (containing this cluster) i could use my VI and .... finished. But I don't know how to get the whole attribute cluster. If I look at the class as flattend data I can't find the type descriptor of the cluster, just class name and something else containing the class name. In the data string there seems to be all data, but I can not extract that in general if I don't have a meaningful type descriptor. Let's try it the other way round: how could I get the the needed type descriptor out of the classname? Would that be possible maybe? Bye Quote
Aristos Queue Posted July 2, 2010 Report Posted July 2, 2010 On 6/25/2010 at 7:50 AM, KoBe said: But I don't know how to get the whole attribute cluster. You don't have a mechanism to do this, and if you find one, it's a bug that should be fixed. The class' data is private. If the class does not provide a mechanism for you to get at all of its fields, you do not have any way to get at all of its fields. This is by design.Some folks have figured out ways to take the flattened string for some known cases and manipulate that directly. That's a hack that can be made to work, but there are limitations to that approach. The Read All Attribute VIs mechanism that you mention at the start is the right, good and correct way of doing this. Quote
The J Posted July 7, 2010 Report Posted July 7, 2010 On 6/24/2010 at 6:59 PM, kugr said: From a different perspective, can you even do what you want with a arbitrary cluster? That is, go from a cluster directly to an array of variants. The Variant To Data function can do this. Wire in an array of variants into the type input and a variant representing your cluster into the variant input. See the attached image. This also lets you go from a variant containing an array to an array of variants. Quote
