Paul Posted June 29, 2004 Report Posted June 29, 2004 I was just wondering if anyone knew what would be the easiest way to execute a frame of a flat sequence for a user specified amount of time. All ideas are welcome. I was playing around with the elapsed time control but couldn't get it working. Thanks for your help. Quote
Michael Aivaliotis Posted June 30, 2004 Author Report Posted June 30, 2004 I'm attaching an image that shows a 1000ms (1sec) delay used. Actually, using a sequence structure in this configuration is considered bad form. It is better to use a state machine architecture. If you want more information on state machines then read the FAQ: What is a State Machine? Quote
Bryan Posted June 30, 2004 Report Posted June 30, 2004 Yes, with a state machine, you can keep coming back to your "timer case" so that you don't have to put multiple instances of the timer in between each piece of timed code. Quote
Paul Posted July 1, 2004 Report Posted July 1, 2004 I got this part working. Thanks for everyones help. Quote
