GOOP - overloading constructor
Hi you GOOP enthusiasts
I redesigned the last two weeks my current application using GOOP (loving it, by the way). Now I came across one point where I need to use an overloaded constructor.
I was wondering if it is good practice to use polymorphic VIs to do it or just forget about using overloaded methods.
Why I want to do this:
my current constructor has several inputs which were marked as "required" and now I need in one calling class just the generated object without any functionality (because of design reasons).
I'm really curious about your positions about that
cheers,
Christian
I guess you guys were all at the NI-Week the last couple of days, so that's why there was now answer.
I thought about the overloading method and I didn't see why I shouldn't do it...So I just did it....
I have now for that particular class two constructors. One Class_Create.vi with some recommendet and some required inputs (so basically I use an overloaded method already) and one Class_CreateEmpty.vi with no connectors at all.
I probably missed your first post.
For what it's still worth.. That's how I usually do it too..
Another way would be to have just one constructor and tell it how to construct using e.g. an enum parameter (the Report Generation VI's class does this), but this requires you to have all possible parameters for all construction actions. I wouldn't recommend that.
