Signal generation
Tan_godo
Can i generate 2 signals of different frequencies simultaneously on NI 9264.
The generated signal frequency will be in the range 1 HZ - 10K .
I am making use of the "Daqmx Write--NChannel Nsample" and "Daqmx timing " block , both channels generate with the same frequency since it depends on the sample clock rate set .
How do we set different sample clock rates simultaneously.
