Trin Posted August 19, 2010 Report Posted August 19, 2010 hi Lavas, i am trying to use Set Mesh parameters, to draw lines between some marked points on the cube. By using "find object" i can delete the marked points. I couldnt figure it out how find object can be used for removing meshes, so any idea? shall i used find object and then remove. object or there is any other method? Looking forward hearing any idea. Trin Quote
