ancle Posted July 17, 2004 Report Posted July 17, 2004 When I click the increment button two times and then click decrement button two times. The value is zero. However, when I click the increment button there times and then click decrement button there times. The value is not zero. Someone helps me. Thanks. The attached VI is V7.1 Download File:post-518-1090026940.vi Quote
Michael Aivaliotis Posted July 17, 2004 Report Posted July 17, 2004 Hmm, it appears to be a bug that's reproduceable in LV7.0 and LV7.1. Can someone else confirm this? I recreated the same VI in LV6.1 and it behaves as it should. It appears to be some kind of rounding error bug. I found a work-around: 1. Right-click on the control and select representation>SGL 2. Right-click on the control and select representation>DBL. It will work now as expected. Quote
JohnRH Posted July 17, 2004 Report Posted July 17, 2004 The bug shows up here on Lv7.1, Win2k, P4 Quote
