PA-Paul Posted September 2, 2010 Report Posted September 2, 2010 (edited) Hi All, We're using labview to control a measurement system which comprises several moving axes, a source and a detector. We have a whole suite of software written now in labview for control and acquisition with the system and (separately) for post processing acquired data. One of the functions of the measurement system is to acquire 2D data "maps" and then process the data and display it to the user. For the type of measurement we're doing a dB contour plot of the data is extremely useful. At the moment, we have manage to achieve this using the 3D plots in labview (8.6). But we want to be able to make cursor measurements on the plots as well, which is where things get tricky - although we can make the 3D plot simulate a flat, 2D contour plot, the cursors within the 3D plot are always in 3D... so it's not at all obvious where on the flat projection of the contour plot the cursor is actually placed. The ideal solution would be to have a genuine 2D plot with the contour lines on it (as opposed to using the 3D activex graphy thing), but I can't see anywhere within labview how to do this... I can get nice looking intensity plots of the data, but I want contour lines (with user selectable dB interval). Is there any easy (i.e. pre-existing) labview code that will let me do this? I can't imagine that I'm the only one who's interested in doing this with data acquired in labview.... Running inside the labview IDE I can use the MatScript node and the matlab "contour" function, but this app requires building into an exe and running under the labview runtime engine (which apparently you can't do with matscript functions...) Anyone know any good solutions for doing this? Any suggestions welcome (I'd probably even pay for an add on if one existed... well, maybe...) Cheers Paul Edited September 2, 2010 by Ic3Knight Quote
Grampa_of_Oliva_n_Eden Posted September 2, 2010 Report Posted September 2, 2010 On 9/2/2010 at 7:23 PM, Ic3Knight said: Hi All, We're using labview to control a measurement system which comprises several moving axes, a source and a detector. We have a whole suite of software written now in labview for control and acquisition with the system and (separately) for post processing acquired data. One of the functions of the measurement system is to acquire 2D data "maps" and then process the data and display it to the user. For the type of measurement we're doing a dB contour plot of the data is extremely useful. At the moment, we have manage to achieve this using the 3D plots in labview (8.6). But we want to be able to make cursor measurements on the plots as well, which is where things get tricky - although we can make the 3D plot simulate a flat, 2D contour plot, the cursors within the 3D plot are always in 3D... so it's not at all obvious where on the flat projection of the contour plot the cursor is actually placed. The ideal solution would be to have a genuine 2D plot with the contour lines on it (as opposed to using the 3D activex graphy thing), but I can't see anywhere within labview how to do this... I can get nice looking intensity plots of the data, but I want contour lines (with user selectable dB interval). Is there any easy (i.e. pre-existing) labview code that will let me do this? I can't imagine that I'm the only one who's interested in doing this with data acquired in labview.... Running inside the labview IDE I can use the MatScript node and the matlab "contour" function, but this app requires building into an exe and running under the labview runtime engine (which apparently you can't do with matscript functions...) Anyone know any good solutions for doing this? Any suggestions welcome (I'd probably even pay for an add on if one existed... well, maybe...) Cheers Paul You can configure the 3d graph to show you the project onto any of the planes you wish. Ben Quote
PA-Paul Posted September 2, 2010 Author Report Posted September 2, 2010 Ben - You're absolutely right, but the cursors always appear in "3D" and "latch on" to the positions the points would be in in 3D if it weren't for the fact that only the projection is showing. Also, it's much harder to customise the 3D graph - I find the axis labels look clunky, and I cant seem to get a decent "tight fit" for the projection on the map... a 2D graph (like the matlab "contour" plot would be the ideal solution for what we're trying to achieve... Is there any (built in) way to calculate the points of the contour lines and then plot them in an XY graph? i.e. each contour line would be an individual plot within the XY graph? so I feed my 2D data array into a magic function which calculates the path of each desired contour (i.e.-3dB, -6dB etc) and then I plug those into an XY graph... Any more thoughts gratefully recieved! Thanks Paul Quote
GregSands Posted September 2, 2010 Report Posted September 2, 2010 (edited) I wrote my own, based on this paper: http://www.springerl...750730487puqm0/ - it works but would need some tidying before I shared it! But a better option is perhaps to directly call the VIs that end up being called by the Mathscript contour function, namely vi.lib\imath\engines\lvmath2\RunTimeEngine\BuiltInFunctions\contour\NIMS_contour.vi (I presume this is legit - at least on the dark side ). Not this routine itself, which has a RUN_TIME_ENGINE check, but the routines called from here: This begs a related idea I've had - there are a few very useful routines in the Mathscript library that are not "available" in G. That would include these Contour routines, the Delaunay Triangulation, and some other geometric functions like Convex Hull and Polygon Area. Why shouldn't these have menu entries in the main menus, maybe under Mathematics. The low-level routines are pretty much independent of any Mathscript-related variables. It seems detrimental to LabVIEW overall to restrict these to using Mathscript. Edited September 2, 2010 by GregSands Quote
PaulL Posted September 3, 2010 Report Posted September 3, 2010 I think this is also important to consider: As I understand it, you can now deploy MathScript code to real-time targets. On the other hand, NI took all the MathScript functionality out of LabVIEW/Developer Suite and put it in the MathScript RT Module. So be wary that if you are developing MathScript scripts in earlier versions of LabVIEW you will need to purchase a toolkit to use them in later versions. Or am I missing something? Quote
GregSands Posted September 6, 2010 Report Posted September 6, 2010 On 9/3/2010 at 4:49 PM, Paul_at_Lowell said: I think this is also important to consider: As I understand it, you can now deploy MathScript code to real-time targets. On the other hand, NI took all the MathScript functionality out of LabVIEW/Developer Suite and put it in the MathScript RT Module. So be wary that if you are developing MathScript scripts in earlier versions of LabVIEW you will need to purchase a toolkit to use them in later versions. Or am I missing something? Yes, I should have also mentioned that you would need the MathScript RT module in order to use this routine. However the contour routines can be called directly rather than through the MathScript node. Quote
JesseA Posted September 10, 2010 Report Posted September 10, 2010 Paul, Would the MathScript contours function (legacy name contourc) meet your needs? It returns the same data that contour uses but without popping up a plot window, so it is supported in the Runtime Engine. Greg, You'll be happy to hear that we are working to bring many MathScript algorithms into the LabVIEW palettes. All of the ones you mentioned are currently on our road map. If you have any other requests, please let us know! And just a general comment about using the MathScript internal VIs on your diagrams. I can't think of any major harm in doing this, besides the risk that the API will change between versions. For example between LabVIEW 8.6 and 2009 all of the built-in function internal VIs were refactored and renamed. If you do ever use these VIs in your application, I'd recommend making a copy of the entire hierarchy to avoid being bitten by changes like this. JesseA LabVIEW MathScript R&D 2 Quote
GregSands Posted September 13, 2010 Report Posted September 13, 2010 Jesse - That's sounds great! Makes a lot of sense to have the core functionality easily available. The most useful function for me that I didn't mention above would be intrp2d_uneven for 2D interpolation of scattered data. Hope you can also add the use of parallel for loops where applicable. Quote
JesseA Posted September 13, 2010 Report Posted September 13, 2010 Greg, It looks like interp2d_uneven is also planned as part of the effort to bring more MathScript algorithms into LabVIEW. It seems you have a similar wish list to our internal developers! Adding more parallelism to the analysis functions is an area of active research. Automatically parallelizing MathScript for loops is also tantalizing, but we'd have to figure out a way to make it configurable in case the parallel loop doesn't perform as well as the serial one. Thanks for your feedback! JesseA LabVIEW MathScript R&D Quote
PA-Paul Posted September 15, 2010 Author Report Posted September 15, 2010 JesseA, Thanks for the response, that does sound like it may be useful (the contours thing - and having this functionality direct in palettes!). One quick question, just to be sure, I just need to create my own subvi with a mathscript node in it with the necessary mathscript functions and then when I build an exe,it'll all work by magic? Do I need to include any additional installers for distributing the code if I've used mathscript nodes? Thanks again for your help. Paul Quote
PA-Paul Posted September 15, 2010 Author Report Posted September 15, 2010 More excitement and problems - I have the full dev suite of labview 8.6.1, but I can't find mathscript nodes... I tried to place one from the labview help, but it says "object not found"... where do I install this from?! Thanks Quote
JesseA Posted September 16, 2010 Report Posted September 16, 2010 Hi Paul, You are correct that it should just work when you built a MathScript node into an application. The MathScript node just calls some subVIs in vi.lib and they are pulled in to the application the same way any other subVIs are. If the MathScript Node does not appear on the structures palette and the MathScript Window entry doesn't appear under the "Tools" menu, it usually means that you don't have the correct license for MathScript. Try opening up NI License Manager and checking your licenses for LabVIEW 8.6.1. You need to have one of the licenses with "MathScript" in its name. Jesse Quote
PA-Paul Posted September 17, 2010 Author Report Posted September 17, 2010 Thanks for that, I checked the licence manager and it said the license for 8.6.1 professional with mathscript was out of date... I updated it and it works fine now! Thanks again Quote
