Can't open remote panel from RT machine on the host side
amorris
I am new to both real-time and remote panel connections using invoke nodes. The program I am trying to run is a host machine application, which is trying to open a remote front panel on a real-time machine. The attached files show the invoke node that seems to be causing the error, as well as the error message from LabVIEW.
From what I can tell, the host is successfully connecting to the RT, but when it tries to open front panels, the server refuses the connection. Also, it is a sporadic problem. It occurrs maybe 85% of the time.
Can anyone give me direction as to what may be causing this issue?
Thanks in advance!
post-18044-078865100 1284670753_thumb.jp
post-18044-000676300 1284670761_thumb.jp
Thanks in advance!
What version of LabVIEW are you using?
Here is a link on ni.com that discuss some Problems with Remote Panels in LV2009.SP1 including workarounds
