Rotate rectangle in deg.
hi all,
i want to rotate a rectangle without using ni vision toolkit only using simple
vi and using bounding rectangle so. can any one tell me how to rotate rectanglein degree
coz i'm new in vision.
reply
Hi Pravin,
Check in the Mathematics/Geometry palette. There is a 2D rotation matrix VI. (2D Cartesian Coordinates Rotation.vi)
See this link for how it works.
I think that's what the function does behind the scene. A rectangle is simply one case of any number of geometries you can make with this function's inputs.
NI Vision rotation algorithm is more complete because it will interpolate colours when the rotated pixel positions are not integers, but otherwise it's the same. The rotation matrix in 2D is exactly what you state above.
Rotation of points.vi
post-10515-051716400 1284913530_thumb.pn
