tims Posted July 22, 2004 Report Posted July 22, 2004 Hi All Have you ever clicked on a dialog (modal) subVI on a running application? Have you ever left a dialog subVI open then run the main application?? And the only way out is quitting the application, via the task manager, with the resulting loss of work. I too feel your pain.... To combat this plague, I have made a utility that will get you out of these situations with out going for the 3 finger salute. It is quick and simple and no special tool required! Tim Download File:post-535-1090468439.vi Quote
tims Posted July 22, 2004 Author Report Posted July 22, 2004 Oh yeah, I forgot to mention... You must run it from explorer!!!!!!! It has been setup to run when opened, because If it is already opened you can't click on it to run it. Quote
m3nth Posted September 18, 2004 Report Posted September 18, 2004 What a great idea! Modal dialogs also made my life completely miserable when I first started using LabVIEW. My solution to this problem now is to use the "Compiled?" flag I usually carry globally to set the modal properties for each dialog box I create. The first time the dialog is called it will check the flag to see if the VI is compiled (running in an executable) and set the window property to Modal/Dialog if so, Floating if not. This works great for developing when you're going to compile the final product, but your little app lets you develop exactly as the app will be run, especially if you're not compiling. For users curious to peek at the source code but can't figure out how to open it, here's one way: Quote
