How to minimize image rotation time
hi all,
i am rotating an image without using NI Vision Toolkit 'but
it takes more time as image size increses, iwant max 20 ms for max (1024 by 980 )
if anybody knows better technique for the same please reply.
please find the attached code for reference
Your example VI has IMAQ functions in it so I can't run it here at work.
Why don't you want to rotate it using IMAQ functions? Why do all the work yourself?
Shane
Shane
PS YOu can also simply set the coordinates for the IMAQ functions which allws you to specify areas of interest without even having to rotate the image.....
hi all,
You could use Graphics Magick
I achieved 6 ms for 1024x980 image rotation
